BUTAPHOSPHAN ESTIMATIO BY HPLC
Is it possible to determine butaphosphan by using UV-Detector?
Butaphosphan has no UV activity. You can try t do indirect detection which is not a very good approach, derivatization or alternative detection techniques (ELSD, RI, CAD, MS)
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
Can you suggest any alternative method
Do you have access to any other detection techniques - ELSD, CAD, RI, MS, nitrogen detector?
Vlad Orlovsky
www.helixchrom.com
None of the technique is available
you can try indirect detection, but it is not of my favorite approaches. You can add some neutral highly UV active compound into the mobile phase and observe your compound as a negative peak.
Vlad Orlovsky
www.helixchrom.com
Users browsing this forum: Google [Bot], Semrush [Bot] and 6 guests
