pH of compound in solid state
Hi
can anyone please tell me how to measure the pH of a compound which is in solid state. I know its a stupid question to ask :roll: but i need some quick response on this.
thanx in advance.
Prashant
Prashant P. Naik
I was really tempted to say to use a "solid state pH sensor" but I won't...
How about dissolving your compound in water and measuring the pH? If this is not a possibility then you will have to justify your answer starting with what dissociation constant is etc...
pH is a measure of the concentration of H3O+, this is probably VERY low in a dry solid.
Hi 2 all
I agree tht if the compound is soluble in water v can measure its pH by dissolving it in water but
- how much amount of sample compound should be dissolved in distilled water
- should the complete compound added must get dissolved in water
- can v use any other organic liquid (which is miscible in water) in proportion with water in order 2 completely dissolve the compound
- if still the compound is largely insoluble then how can v measure its pH
-what if i dont know the dissociation constant of compound.
-if i know the dissociation constant then i should use the following formula
pKa=pH-log [X-]/[HX] but i should know hw the compound is getting dissociated , m i right
:scratch:
Prashant P. Naik
