How to run chromeleon on a network?
What I have, is a IC system and a PC which I use to start the server and the client (chromeleon 6.50).
What I need, is to be able to run an other session of the client from an other PC on the network, so that 2 persons can work at the same time.
here is the Licenses:
Is it possible to do what i need with the licenses I have, or do I need others. If it is the case, which one(s) ?
Thanks for your replys and sorry for my very bad english :/
As far as I know you will need an extra "floating" client license.
Talk with your Chromeleon support. I hope it helps.
Csaba
Do you want to simply be able to see the data or will you want to be able to perfrom batch runs and control the IC system from the second PC?
For now I just want to be able to look at the data, work on the chromatograms and print out the reports, while someone else is working on the PC which controls the dionex.
Check the "floating" client license. It is not that expensive.
Check the details with Dionex so everything turns out right.
